Re: 424 ignition problem
Posted by Bob on November 01, 2008 at 00:43:10 from (69.178.228.68):
In Reply to: 424 ignition problem posted by Tedly on October 31, 2008 at 22:50:42:
The wire from the starter to the coil bypasses the ballast resistor during cranking (with the starter).
If you have a bad wire from the ignition switch to the ballast resistor or a bad (open) ballast resistor, the tractor will act just as you describe.
I can't remember the exact circuit, but don't think it will crank (with the starter) if the actual ignition switch has failed.
I don't know the exact value of the ballast resistor, but expect a reading in the 1.5 to 2.5 Ohms range.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
