Posted by John T on November 01, 2008 at 05:36:27 from (66.244.97.31):
In Reply to: 424 ignition problem posted by Tedly on October 31, 2008 at 22:50:42:
Ted, Im NOT at all familiar with that particualar tractor but can provide information about how tractors work that use a ballast resistor and a start by pass system to put battery voltage to the coil ONLY while cranking for a hotter starting spark (cuz ballast is then by passed):
1) If it uses a starter solenoid like a Ford type that has an extra little I terminal, that terminal is hot ONLY when the solenoid is engaged (its other S terminal gets voltage from the push to start switch so it cranks) so when you press the start switch the feed from the I terminal effectively by passes any external series Ballast Resistor by sending that hot voltage direct to the coils input (or output side of ballast, same point electrically) BUT ONLY WHILE CRANKING.
THEREFORE ifffffff the tractor has such a solenoid and iffffffffff it has an external ballast resistor and iffffffff it uses such a start by pass system and fires ONLY while cranking but NOT otherwise, the Ballast is bad/open orrrrrrr theres another open/bad/missing wiring issue such as in the circuit from the ignition to the ballast and/or from ballast to coil i.e its such that the regular feed from switch to and through ballast and to the coil is open or broke somewhere so the only way n time the coil is hot is when the start switch is depressed......... YOU NEED A CONTINUOUS UNBROKEN WIRING CIRCUIT FROM IGNITION SWITCHES IGN OUTPUT TO AND THROUGH BALLAST (good ballast that IS NOT OPEN) TO THE COIL.
The other possibility is the Ignition switch itself is bad (or the input voltage feed isnt there) and its NOT supplying hot voltage out its IGN output (to ballast and coil) when its turned to ON. There has to be a hot BAT input feed to the ignition switch (check for that and any blown ignition system fuse),,,,,,,,,, and the IGN output terminal has to get hot when its switched to ON,,,,,,,,,and there has to be a good circuit/wire from there to and through a GOOD ballast......
2) Instead of a Ford type solenoid with an extra I terminal (it may have a regular solenoid without any extra I terminal thats hot only while cranking), some tractors used a switch contact arrangement (like a double pole switch) as a source for a hot feed to by pass any ballast ONLY WHILE CRANKING. If it uses such a switch arrangement again it feeds hot voltage to the coil (by passing any ballast) ONLY while cranking so if it fires when cranking but NOT otherwise, similarily look for a bad/open ballast,,,,,,,, or a bad/open/missing wire from the regular ignition switches IGN output to and through a ballast to the coil,,,,,,,,,,,or a bad switch that isnt supplying hot voltage out its IGN terminal when ON.......
SUMAMRY: Id be checking any Ballast to insure its continuous and NOT an open circuit,,,,,,,Id expect its resistance to be in the 1.2 to 3 ohms or so (depends on the coil),,,,,,,,,,,Id be checking the regular Ignition switch to insure theres hot battery voltage out its IGN (to ballast and coil) terminal when its ON,,,,,,,,,Id insure theres a hot feed TO THE SWITCH on its BAT inupt terminal and no blown fuses or bad wiring to the switches input (has to be voltage to the switch before it can provide output voltage),,,,,,,,,,,,,Id insure theres a good wiring n circuit from switch to and through ballast to coil........
Let us know, check that ballast and ignition switch and wiring ..........
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
