460 coil wires
Posted by iowafarmall on November 02, 2008 at 19:40:05 from (66.43.214.78):
put electronic ignition on 460 today. It was wired for the points with a black switched wire and a white wire on the negative terminal of coil and the wire going to distributor on positive terminal. The ignition instructions said to have red wire and switched wire on positive side and black wire of ignition on neg side. Where do I put the white wire? It was not starting with the white wire still on the neg coil terminal but it started and ran fine when I took wire off. Do I put the white wire over on the positive side or does it belong somewhere else?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
