Posted by Ted in NE on November 08, 2008 at 09:39:07 from (74.85.105.88):
In Reply to: 560 hydrualic problems posted by farmallguy3 on November 07, 2008 at 17:11:30:
When you removed the fast hitch you need to remove the rod that runs along the left side of the trans. cover. Lock the linkage that the rod was hooked to so it can't move. With the engine running move the lever that you used to run the fast hitch carefully one direction or the other untill the hyds come off high pressure. Then tie the lever so it can't be moved. This will center the teledepth valve spool. It is possible that the gears in the valve have broken teeth. Will have to be repaired. Look at the end cap on the valve that runs the fast hitch{back cap}. Could have a cap screw in it. This was used to center the spool if it ever had a single row beet harvester on it. Had to remove the fast hitch to mount the harvester
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
