Wild Bill, Im not sure what exact Mag youre dealing with, but on many mags where the rotor tip is just prior to when the impulse spring winds up n then trips IS NOT DEAD LINED UP WITH THE TERMINAL TO WHICH ITS GOING TO DELIVER A SPARK JUST SHORTLY AFTERWARDS (its physically located JUST BEFORE the place where it will be after/when the spring trips) ...... Theres no spark until the impulse trips, and when it does the rotor tip ONLY THEN passes by that correct terminal so the saprk jumps from the rotor tip to the caps terminal. I AM FAMILAIR with the Wico C and X (NOT XHD) Mags used on Two Cylinder Deeres and to time them as I say the rotor tip IS NOT where its going to be AFTER the spring has wound up n then tripped.
I time them (Wico C and X used on Deeres) to the point the mag trips/impulses/snaps right as the No 1 piston is at TDC and prior to snapping/tripping the rotor tip is JUST BEFORE the upcoming No 1 cyliners inner cap terminal. One can first RETARD THE TIMING, then get the piston to TDC, then slowlyyyyyyyyyy advance the timing just to where she snaps/trips
Hope this helps even though Im not familiar with your particular mag, let us know
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
