Posted by Janicholson on November 12, 2008 at 19:07:12 from (66.173.50.128):
In Reply to: For donald schnupper posted by Dr. Bert on November 12, 2008 at 18:52:08:
Many manifolds are prone to cracks and self destruct. Even modern auto engines have issues with the manifolds. Extreme heat (near 1200 degrees) and then cooling to ambient summer temps, or below freezing in winter then repeating that thousands of times. External cracks and holes (rustout) is most common. Internal between the intake plenum, and exhaust heat transfer section (especially dual fuel manifolds) is next, and difficult to find. Yours probably does not have an internal crack, if it was loose. Checking well requires taking it off, and plugging the exhaust pipe hole and filling it with water while on its back and the ports are up. This will show leaks internal to the intake. Some exhaust manifolds have intentional holes designed to let water out befor it does damage. These are less than 1/8th" or so and can be plugged to check for cracks, then unplugged for operation. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
