Re: lead addative / winter oil viscosity
Posted by RN on November 13, 2008 at 18:07:07 from (96.60.76.229):
In Reply to: lead addative / winter oil viscosity posted by 1938 F20 on November 13, 2008 at 15:16:44:
F20 can use straight unleaded gas- old manuals suggest 1 cup of engine oil to 5 gallons of gasoline. The engine doesn't run fast enough- cam duration isn't open enough to cause exhaust valve seat erosion problems. IHC Super H,Ms may have some erosion if run steadily at 1800 RPM, Cases and AC late 50s noted to also be susceptable- this from a Wallaces Farmer articles early 80s when unleaded became standard- 1500 RPM seemed to be the start of extra erosion. Ford Ns were not at risk as Ford had used stellite seats to start and JD twins didn't run too fast and valve timing didn't have long duration. F20 governed 1000/1200 RPM- just add a bit of oil to gas like old manuals suggested. Oil for winter? Try 10-30 to ease cranking- F20 is more of a splash system with rod bearing trays and crank ball bearings instead of plain bearing pressure lube. the 10-30 will flow and splash a bit easier than straight 30. RN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
