You can probably see the release bearing through the access hole, see if it turns or seems loose, etc. You might try adjusting the clutch and TA, doubt if that helps -- but to fix whatever it is you have to split the tractor. New clutch kit including rebuilt clutch, pilot and release bearings are about $250 minus $24 core charge from Steel Wheel Ranch 785-548-7437. You can find the bearing locally if thats what it turns out to be.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
