DEo not run it that way! There is a seal in the hydraulic pump which can go out causing a massive "filling" of the oil pan. This is not engine oil, and must be repaired. The seal will be easy to get at, but could be either a lip type seal, or an O ring. If the shaft has a groove in it (any) it will need to be repaired with a "Speedy Sleeve" This is a thin sheet metal tube that is placed over the worn shaft. (NAPA and others have them) If it is a O ring style, the housing may need to be opened up a tiny bit to allow the sleeve to fit inside the location of the O ring. It is a machine shop type of repair if that is needed. If the bushings in the pump are worn and allow any play, the pump is probably toast. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
