Posted by LMack on November 15, 2008 at 15:36:18 from (74.224.122.26):
In Reply to: M won't start ??? posted by Brad in Colockum on November 15, 2008 at 11:54:16:
The new gasoline with so much added ethanol has caused some problems. The ethanol tends to dissolve the rubber gaskets and seals. If the carburetor is leaking either the floats are bad, the float valve is bad, a gasket is bad, or there is trash in the carburetor. The carburetor most likely needs a boil out and rebuild.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
