Posted by David Goode on November 15, 2008 at 18:01:09 from (69.19.14.25):
After locating a new clutch pedal and brake pedal shaft for my '52 Super M I have encountered a new problem with the new shaft. The Woodruff key slots on the NEW shaft do not align as to install the left brake pedal and brake actuator. I inspected the new shaft against the old shaft when it first arrived yet failed to notice that the woodruff slots where off by about 45 degrees, as to not allow the brake actuator to "lock" with the shaft. I have Emailed Yesterdays tractors about the problem and am awaiting response on what to do with the new shaft. Has anybody else had this problem? I had to fix the brake oil seals in the transmission while I was doing this fix to and drained and refilled the transmission with new oil after I installed the new seal and brake shaft, needed to possible remove the new shaft will I have to drain the transmission again, and how low can I drain it so as to just to remove that shaft? Are their any other possible fixes? Any response is much appreciated. -David Goode Coggon, IA
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
