Well you can just change the pinion, but it will make one heck of a racket. So if your changeing the pinion you should change the ring gear with it cause each ring and pinion are made as a matched set.
As far as the axle pulling yes. You just need to remove the bearing/seal retainer on the end of the axle, and remove the bolt holding the bull gear to the axle and you can pull the axle out. You kind of have to wobble the axle to get the gear to slide off. It helps to have another set of hands, or use shims to hold the bull gear up so it doesnt drop to the bottom of the transmission case.
The photo is a 560 axle but it works the same for an H.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
