It must be operated at least 1.5 to 2 minutes on gas before switching. It is necessary to have solid Diesel compression to make it ignite, so if it will not, it may be any factor reducing compression, as Chuck's repair indicates, it could be misadjusted starting valves, or stuck starting valves, or bad/stuck rings or bad main valve adjustment (less likely). If it does pump air out the spark plug holes on diesel mode, after checking full motion of the linkages to the head, pull the Valve cover and see if the third valves are sticking open. Tapping them with a plastic hammer, squirting with PB Blaster, and repeated tapping may free them W/O head removal. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
