Re: McCormick-Deering Compression PSI
Posted by ScottyHOMEy on November 18, 2008 at 13:59:37 from (71.241.193.150):
In Reply to: Re: McCormick-Deering Compression PSI posted by Dave Koenigsfeld on November 18, 2008 at 13:40:03:
Sounds like you're going about it right. The open throttle is to make sure there's no restriction to incoming air and makes it easier to crank.
That's still quite low (the 113s/123s in my tractors are in the 80-85 range and don't require any special effort to turn) and I doubt it would even fire with compression as low as what you're showing.
Just sittin' in the armchair I'm gonna guess you've got some combination of stuck valves, and badly carboned or eroded valves or seats.
On the rings side, they could be anything from completely worn out to broken and missing.
You don't say (and may not know if you just came into it) what the worst known condition of the motor is. Ever stuck? If so, how did they get it loose? (Towing can do nasty things like bend valves and lifter, break rings . . .)
I don't know that motor at all, but if it has a typical valve cover, I'd start by pulling that and looking things over.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
