Not sure which parts you need. My 2606 has a auxillary cannister filter that came with the IH 3000 loader mounted in the loader frame. Changed it over a week ago and dropped it on the ground. Wasn't sure what parts went where then.
A flat aluminum appeared to go on the inside of the cannister on the bolt. Then the small hole of the filter which has a rubber washer on it. Then the large end of the filter at the open end of the cannister had a plate recessed a few inches. I put the pyramid shaped spring with the small end on the filter and the large end seemed to want to fit the filter base. Tightened it up and no leakee. I thought the flat filter going against the cone shape of the cannister would cause it to leak there because the filter doesn't seem like it would go flush against the aluminum washer. I did figure out the spring can't go on the inside of the cannister first before the filter.
I'll let the others chime in here but I wonder if you can get by without the washer and spring.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
