Len Remember well driving the 10-20 on steel & Regular on rubber. Dad had rubber put on the Regular around 49 or 50. Had the spokes cut off & rims welded on. Used 36's so the rim just cleared the top of the brake drum. Bigger wheel made it run "down hil". Dad thought that would be bad for oil pressure, so had a spacer welded into the steering post below the lower bearing, but above the wheel spindles. That made it sit level. Shop did bad welding job, broke off once. On second try, had 3/4 in dowel pins put in the spacer before welding. That held. My favorite job was cutting oats. With a "suicide" knob & brake cable set right, could cut a perfect square corner. Of course, with the binder seat sticking out back, Dad got a wild ride on the corners. Had rubber on front of the 10-20. Plowing was easy. Just cut the wheel a tad to the left so tire scrubbed the edge of furrow, it would follow across the field. If we got tired, & Dad wasn't watching, my brother & I would sometimes set it up, then get off & walk along side for a while. memories of the 50's Willie
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
