Re: SLipping TA on SMTA
Posted by Owen Aaland on November 22, 2008 at 17:53:52 from (65.161.86.88):
In Reply to: SLipping TA on SMTA posted by GordoSD on November 22, 2008 at 16:26:24:
.050 is more than enough clearance to release the direct drive clutch. There is no adjustment to the low side. It is a one way clutch (ramp and roller assembly) that engages when the TA clutch is released and over rides when the the TA clutch is engaged. If it slips in low side it is ALWAYS the one way clutch that is the problem.
Go back and adjust the clutch linkages as they should be and don't worry about the way it looks inside.
When properly adjusted you should have about an inch of free travel on the clutch pedal at the platform. The TA handle should have a couple of inches free travel. The connector link should be adjusted so that as soon as either the TA lever or the clutch pedal is moved, the other control should start to move. When facing uphill the transmission should shift freely with the TA lever forward.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
