Posted by Janicholson on November 23, 2008 at 06:51:42 from (66.173.50.91):
In Reply to: Delco Regulator posted by brian2 on November 22, 2008 at 17:00:55:
It is likely to work. There is a possibility that it is for the B type generator which you do not have. If the seller will check it you will know. Have the seller check to see if the F terminal is connected to the ground of the regulator base with an Ohm Meter. If it is, it should show almost no resistance. It is correct foe it to be a grounded terminal for the A type generator on yours. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
