Posted by mattofvinings on November 26, 2008 at 09:54:15 from (198.208.159.20):
In Reply to: '48 H Hydraulic Hoses posted by chad504 on November 26, 2008 at 06:43:55:
I would be with El Toro on this...use NPT to JIC male, put JIC female fittings on both end of the hose. This way you never have to fight with the hose or rotate the entire hose (if one had an NPT male crimp fitting)
Often if you can layout the hose path with something like a garden hose or a scrap piece of wire you can arrive at a length. Take this to the hydraulics shop with you.
If you use the "reusable" fittings as El Toro has pictured I find a couple drops of cheap rear axle lube (EP oil) to be the best assembly lube.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
