Re: international 340 utility - power steering - HELP
Posted by bc on November 27, 2008 at 18:50:49 from (68.88.175.43):
In Reply to: international 340 utility - power steering - HELP posted by goose1 on November 27, 2008 at 01:58:50:
If yours is like my 2606 with the 2 way cylinder under the front axle, then I just rebuilt mine. Is the piston stuck or the seal blown out and fluid bypassing? Raise the wheels and see if they and the piston move by hand. To remove, just remove the 2 hoses, the bolts holding the mount in the middle and the pin.
On mine, the piston is in the middle of the rod and is stationary or fixed solid. It doesn't move on the rod. Go to www.caseih.com and there are 2 search for parts screens. Put in your model or a similar model and the schmatic and part numbers show up.
On mine the rod screws into the block on the end for the pin. Have to put in in the vise to unscrew it to change the packing and orings on that side. The end of the piston rod has a couple flats for putting a wrench on it. Suppose you could break it loose before you remove the cylinder from the tractor.
The design of the 2 way steering cylinger is for fluid to pump through the rod to the other side of the piston and fluid comes out the block to push it the other way.
Post back with what you find out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
