Posted by Janicholson on November 29, 2008 at 06:59:04 from (209.191.204.169):
In Reply to: Re: water in cylinder posted by IndiRon on November 28, 2008 at 19:14:42:
The sleeves in that engine are dry (pressed into the cast iron of the block full length contact. Rarely do they come out easily with the piston in the cylinder, as the piston ring rust has swelled the ring and sleeve so that they are tight. Some crack the sleeve, and cast bore as well. Getting the piston out can (in extreme water corrosion) require it to be removed in pieces. Drilling out the top just inside the rings with a circle of holes, and cutting down beside the pin with a recipro saw or similar. Good luck, JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
