Farmall Tractors Discussion Board
Re: Re: Re: International 3288
Posted by Milan H. Dilworth on December 22, 1998 at 22:34:14:
In Reply to: Re: Re: International 3288 posted by Randy Pendleton on December 22, 1998 at 17:22:59:
I wouldn't be concerned about constantly running it in DD (higher speed side of TA unit), if you're up on your oil maintenance. It's been sometime since I've worked on a 3288, but as I recall it has a solenoid to move the TA shift valve. You need to determine how you can keep it shifted in DD, by either running a hot wire to the solenoid from the battery or simply disconnecting a wire from the solenoid. It shouldn't be too hard to determine.
The newer TA units have a different 1-way mech. which they call the mechanical diode. I believe it has a 3 year warranty on it. I'm not overly impressed with them being any better than the older style, but it may be at least 50/50 and the warranty may be good for your pocket. The newer unit has the problem of not letting the 1-way mech. release, and can cause more damage if it continues to run. It may kill the engine and/or be extra noisy in operation.
Many farmers have replaced own TA's, but the warranty may not apply unless a CASE-IH shop does the work. You should check on this.
Post a Followup
: Re: Re: Re: Re: International 3288
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
