Remove the spark plugs, Remove the valve cover, and the rocker shaft, rockers, and push rods. Be careful to not pull lifters out of their bore, sometimes the pushrods get a suction fit to the lifters, be patient, and keep them in order frnt to back. You will need a lever type valve spring compressor, and a 2' piece of 1/4" cotton rope. Use a 9/16" deep socket as follows. Use a plastic faced hammer and the socket (alone) to loosen each valve keeper. Place the socket o the valve keeper so the socket covers the stem. Rap the socket modestly with the hammer. This breaks the bond of the keepers to allow easy removal. Pull the plugs out. In number one cylinder, push in all but 6" or so of the rope. Hand crank. or use the fan belt to turn the cylinder untill the rope is compressed into the valves holding them up in place. Put it in gear to keep the engine from turning backward. Now use the spring compressor to remove the keeper and spring. Put on the seal as directed in the material supplied with the seals. All cylinders are done in the same way. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
