Just get a small test light(bulb with 2 wires) disconnect a batt cable and hook bulb in between cable and batt post. If bulb lights, you most generally have a drain. Not sure about newer tractors, but newer cars lot of them will show drain that is not really there. Multimeter is not much help on old tractors, need analog tester with moving needle, but then you gotta watch plus and minus or burn out meter. Ohms is for readings where you do not expect any voltage. Ohms the meter is using its own little batt to read through meter.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
