Put the meter on volts. touch the alt body with the neg test lead, and the big terminal on the back with the pos test lead. A reading of battery volts with it connected is correct (not running) Disconnect the big lead. Place the pos test lead on the wire you took off, and the other lead on the post. (not running) if there is more than 0.25 volts (1/4 volt) a diode inside the alternator output bridge is leaking more than it should. if small (tenth of a volt, it is OK. One volt or more will discharge your battery in a few days or less. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
