Re: Rear mounted Mower on an Farmall A
Posted by TractormanNC on December 01, 2008 at 04:54:12 from (209.42.180.114):
In Reply to: Rear mounted Mower on an Farmall A posted by TWheat on November 30, 2008 at 12:12:24:
That bottom pulley/crank arm is keyed and PRESSED TIGHT on the lower shaft. Bearing splitter in the pulley groove and a porta-power will do the job, or tear it down far enough to get it in a press. Takes some seious force to get them apart. Shaft comes out from the front after the pulley is off. BTDT.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
