usually excessive blowby is caused by worn rings, however, it could be caused by other things too, ie, cracked piston, blown head gasket ect. the oil by the exhaust is more than likly coming past the rings and getting in the exhaust manifold, not burning off and dripping out. run a dry and then wet compression test, first, pull all plugs, throttle wide open, ignition off, test each cylinder, write the numbers down, then squirt 2-3 pumps of engine oil in each cylinder, roll the motor over couple times and retest. more than 10% variation, and the rings are worn, low compression with no change, look to valves, head gasket or cracked head. you are prooly due for a major on the motor, but if its a year or two away, try tossing a can of stp oil treatment in the crankcase, it will thicken the oil up and cut down on some of the oil consumption.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
