You need a dual speed PTO assembly. They were available for 1086 and smaller tractors. Best to get the same style as your single speed unit. On later units the lever will drop out of engagement when the engine is shut off. That shaft also is free to turn with the engine off. If you do not get the same style you will also need to change some linkage. You will also need a different coupler inside the the rear frame. The 15 series uses a larger diameter drive shaft shaft so you need a coupler to adapt it to the smaller size on the PTO unit.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
