Re: SUPER MD BOGGING AND SMOKING UNDER LOAD
Posted by mkirsch on December 05, 2008 at 09:46:34 from (64.80.108.56):
In Reply to: SUPER MD BOGGING AND SMOKING UNDER LOAD posted by Keith Y. on December 04, 2008 at 17:09:35:
You only need to run the engine long enough on gas at startup to get it to where it will run smoothly on diesel. Let it run a bit, try switching, and if it won't run, switch back before it stalls. Give it a couple more minutes. After a few times you'll get an idea as to how long it needs to run. As for cooldown, probably not more than a couple minutes unless you're really working the tractor.
CNH is Case NewHolland. The number is the part number that you ask for at the parts counter of your local Case NewHolland (also known as Case IH) dealer. In other words, you can get a new replacement part from the dealer.
Get yourself a quart of Diesel 9-1-1 in the RED bottle. Use about double the recommended dosage. The stuff is a miracle cure. We even put it in an old kerosene torpedo heater that hasn't worked right in years, and I think it fixed it. Before it wouldn't run for more than a few minutes at a time. After we put the 9-1-1 in it, it ran for 3 hours straight before we shut it off.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
