Re: axel shaft H
Posted by Owen Aaland on December 07, 2008 at 19:29:52 from (65.165.246.197):
Kelly VK said: (quoted from post at 17:16:00 12/07/08) Jim,
You seem knowledgable on Farmall H bull gear removal. I need help. THe bearing behind the break seal is out leaking on the brake band. While fixing I noticed the bearing was shot just behind it - the bull pinion bearing? So I took the rear wheel off and put a block between the left and right bull gear bolts so when I loosen it it also slides (forces) it off the axel. Well it slid off about 1/4 so far and now I can feel pressure building on my wrench and the axel isnt moving out of the gear. I can apply more pressure but I wonder if there is something I need to consider before turing harder? Thanks
Kelly
Did you take the outer axle seal retainer off the axle housing?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
