Dear JMOR and others, Many years ago I checked the amp draw of a 12 volt system on an engine mounted on an engine stand with a Sun VAT-40. The draw was 185 amps. Then I substituted a 6 volt battery and the draw was 320 amps, with the engine turning more slowly. The same phenomenon will occur with a weak but not too weak battery. As the starter approaches stall, current flow rises as voltage drops up to a point. This apparent violation of OHM'S law is due to the fact that the starter is both a starter and a generator and when spinning rapidly produces a counter voltage reducing current flow. However, if we were to conduct this experiment with a locked engine, we would have a resistive rather than inductive load and OHM'S Law would be obeyed.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
