Posted by glennster on December 09, 2008 at 13:21:03 from (76.222.57.166):
In Reply to: Farmall M Leak posted by TC2 on December 09, 2008 at 12:49:58:
prolly the oil seal behind the brake drum. you need to pull the cover and brake band, then take the center bolt out of the shaft, thenpull the drum off. there is a seal in there. dont try and take any bolts off behind the cover, you need to work the seal out, then replace it. lot of guys put 2 seals in with gun grease packed around the inside of the outer seal. if its got a clutch on the left side housing, it prolly has an aftermarket m+w sort of live pto set up. we use ta call them a baling clutch, it will have oil seals in there too.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
