Posted by Bob M on December 10, 2008 at 05:52:14 from (151.190.254.108):
(System won't let me reply to the original post...)
Brian - All sounds normal. The ammeter behavior you describe simply means the voltage regulator is doing its job.
The only (minor) irregularity is the observed 10 amp maximum charging current. With anything less than fully charged battery you should see closer to 15 amps at full RPM. This means the generator's 3rd brush may need adjustment:
First use a jumper wire to temporarily ground the regulator's FLD terminal. Now run the engine at full throttle and note the ammeter reading. If is 15 amps or more, do nothing. However if it's LESS than 15 amps, loosen the 3rd brush clamp screw on the back of the generator. Now rotate the 3rd brush a bit closer to the nearest fixed brush, tighten the screw and test again. Repeat if required until you see 15 amps on the ammeter at full throttle.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
