Not to hard to put the utility engine in a H. Utility tractors don't use frame rails so a different front engine cover is used along with as I remember 6 attaching bolts that are 1/2 inch diameter. This front cover needs changed to row crop type along with the crankshaft pulley when engine is installed in a row crop. Row crop front engine cover uses all 3/8 bolts that screw into block. So the problem of 1/2 inch bolts in utility block compared to 3/8 holes in row crop cover needs addressed, not hard to do. Utility may have a exhaust manifold that exits down instead of up in center. Also utility governor is set for more RPM than row crop. Most all other engine parts are the same as row crops. You would get the most power from a farmall 300, 350 manifold and a carb. and distributor from the utility or row crop. Your H parts will work though the Mag may not have the best timing for that engine. Your breather pipe that goes to air cleaner inlet pipe from valve cover on the 300(back of head on H) will need modified. Depending on which front engine cover you use the ignition drive bolt pattern may not match what you want to install there. Late bolt patterns match live hydraulic pumps and late drive housings if no pump is used. Early covers bolt patterns match about 90 percent of H tractor ignition drives.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
