The output of a genny is increased EITHER by turning it faster ORRRRRRR pumping more amps through its Field windings, but thats what the VR regulates. Since you cant spin it faster (unless you change pulleys) the VR is what regulates the Field current buttttttttttt even if you by pass the VR's regulation by dead grounding the gennys FLD post (max charge) then youre up against the gennys max unregulated rating which, if exceeded, (say you make it pump out 25 versus 20 amps) may eventually overheat n damge the fields or armature !!!!!!!!
The limiting factor is the gennys rating and heat dissipation capacity so say you use a smaller genny pulley and dead ground its field sure you may get more out of it butttttttttt for how long before its toast??????? If you wanan get less drastic you might try n adjust the VR's field current control relay (air gaps and/or spring tensions) but im not into advising that over the net, Bob or Jim might be able to, I have like NO specs or data here.
In the meantime,,,,,,,,good tight non glazed belt,,,,,,,good non dished out pulley,,,,good battery and grounds and connections,,,,,, are my best non fool with the VR advice
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
