Posted by mkirsch on December 20, 2008 at 13:41:03 from (67.240.251.254):
In Reply to: M stuck in 3rd gear posted by minnesota red on December 20, 2008 at 13:27:24:
What do you mean by stuck?
Will the tractor move?
Will the shift lever move?
It's very common for these old tractors to get stuck in two gears at once. The main symptom of this is that the tractor won't move when you let out the clutch no matter what gear you put it in. Sometimes the gears will jam and you can't shift it either.
The cause of this is the nub on the end of the shift lever gets worn and slips out of the shift forks. To get it unstuck, you need to remove the lever and manually pry the shift forks back to neutral. To fix it permanently, you need to build up the end of the shift lever with weld and reshape it back to its "new" form.
If the tractor is in 3rd, will move in 3rd, but you can't move the shift lever, you may have major problems inside the transmission. You may have to remove the transmission cover and figure out what is wrong.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
