Check the voltage between the large BAT terminal on the alternator and the alternator case -OR- directly across the battery posts.
With the engine running you should see 14.0 - 14.5 volts. 12.6 volts or less says the system is not charging.
Regarding the "no charge" problem try this first:
Run the engine up to max RPM then push the "excite" button. It may simply be the replacement alternator has a higher "turn on" RPM than the old one.
If that doesn't work pull the aux connector from the alterator then test each connector terminal for voltage. You should see battery voltage at #1 when the "excite" button is pressed. And #2 should show battery voltage at all times.
If the above checks out (indicating the wiring is OK...) the problem could be the replacement alternator has problems. You can isolate the problem with this test:
With the engine running at about 1/2 throttle push the "excite" button. Now take a small screwdriver and touch its tip to the tab inside the D-shaped opening on the back of the alternator (photo). While keeping the tip in contact with the tap ground the screwdriver shank to the side of the opening.
If the ammeter show 20+ amps charge with the tab grounded it means the alternator's internal regulator is bad. However if still no charge the alternator is NG. Note: You can replace the internal regulator yourself for around $10.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
