Posted by Red Mist on December 27, 2008 at 15:17:32 from (72.171.0.147):
In Reply to: low oil pressure posted by r4etired on December 27, 2008 at 15:04:02:
Worst case, the bearings in the engine are shot and you need a total rebuild.
Next worst case, the oil pump is worn out and needs to be replaced.
Next worst case, you need to remove the base plate from the oil pump and true it up on a piece of sandpaper which is laid out on a piece of flat glass. These bottom plates are infamous for warping and causing oil pressure to drop even though the engines themselves are in good shape. They can be "milled" flat by rubbing them on flat sand paper in a figure 8 pattern.
Next worst case, the oil in the engine is way too thin and needs to be replaced with the proper grade oil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
