Most times on that type seat the hole that piviot pin goes through in pipe is worn or broken. Fixed several by making a new pin and some welding. If you unbolt bracket from transmission cover and turn seat upside down you can see problem. Or move seat side to side bolted on tractor and you can see pipe roll in bracket some. If hole through pipe or bracket is very bad you can remove old material and weld a steel bushing into pipe with correct ID for pin. If holes are worn in holding bracket use bushing for oversize pin. If nothing is worn to bad just a oversize piviot pin with holes enlarged to match will work. Be sure to get hole in pipe centered or seat will lean. Also if no worries about removing again the piviot pin can be welded at ends on bracket and ground down smooth.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
