Posted by Janicholson on December 30, 2008 at 13:36:24 from (68.112.156.69):
In Reply to: BN 12volt conversion? posted by Bilko on December 30, 2008 at 12:03:02:
Yes. Bob M wiring diagrams will do what you need. If it has a magneto ignition, things get a little harder, but not much. A mag is grounded to make it stop, and ungrounded to run. THus there is no voltage going to the mag at all, and cannot have any ever. So to make the alternator excite, I would use an oil pressure swithc fromNAPA to make it work The switch has two terminals, and is open when there is no pressure, closed when there is about 3 psi. This oil pressure switch is placed in series with the positive side from the battery. Run a #14 wire from the starter switch on the starter (big terminal attached to the battery cable) to the oil pressure sw, then to the #1 terminal of the Delco SI alternator. The #2 terminal attaches directly to the bigger output terminal of the alternator. The output terminal attaches with #10 wire to the terminal of the amp meter that is not connected to the battery pos post (usually at tha same place on the Starter sw that I refered to before. The wire just mentioned (from amp meter to battery at starter should have a fusable link wired into it near the start switch at the starter. NAPA has fusable links; they protect all systems from letting the smoke out. THe fuse link should be rated at 10 amps over the rating of the alternator you use. (often stamped into the alternator housing) A Hitachi alternator from a mid 80s nissan PU will be smaller and put out plenty It is wired similarly. THere are many descriptions of the Hitachi in the archives to use for terminal marks. Good luck
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
