Posted by Janicholson on January 01, 2009 at 18:09:33 from (64.83.200.187):
In Reply to: Need Wiring Diagram posted by Willy Hall on January 01, 2009 at 16:16:47:
The lighting wire going to the L terminal can be connected directly to the load side of the Amp meter. The Big screw terminal on the Alternator goes to the same terminal (load side of amp meter. The #2 terminal goes to the big screw terminal also. The #1 terminal should go to a wire attached to a oil pressure switch (purchases at a NAPA store, this switch has two terminals and is open when there is no pressure) "T"ed into your oil pressure gauge or line to the gauge. The other terminal of the switch is connected to the positive battery terminal at the starter switch (where the supply to the amp meter is connected (that big post on the switch with the battery pos cable hooked to it.)) THis setup causes the alternator to start charging as soon as the oil pressure is up., and stops charging when the engine is off. No diodes or other stuff needed. I would put a 70 amp Fuse link in the wire going to the Amp Meter from the start switch. As mentioned below, do not connect anything to the ignition. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
