Re: IH 504 hydraulics
Posted by TractormanNC on January 02, 2009 at 15:53:12 from (209.42.180.181):
In Reply to: IH 504 hydraulics posted by Mike (WA) on January 02, 2009 at 14:37:42:
Does the tractor have power steering? If so, the valve you mentioned is a flow divider valve to divert 3.5 GPM to the P/S. There should be a 3/4 in. steel tube leading from the flow divider to the right side if the lift cover where the remote valves are. Cut into this steel line and run to the IN port of your loader valve (open center power beyond). Connect a line from the power beyond port of your loader valve to the steel tube that runs to the remote valves on the lift cover. Excess flow from loader valve must be dumped back to sump either at the fill plug or the PTO adjustment plug on the PTO assembly. There were some posts about this awhile back, search the archives for more info.
HTH
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
