Posted by Janicholson on January 02, 2009 at 21:22:42 from (68.112.156.69):
In Reply to: farmall h clutch pedal posted by Patrick J Cummings on January 02, 2009 at 19:14:54:
Ac CNKS indicates set the freeplay at a bit over an inch, then it should release well. Free play is done with hand pressure as the pedal is pushed down it will begin to get resistance from the pressure plate and get much harder. This is the beginning of the release motion. THat distance is the freeplay measured from the pedal contact point to the platform edge where that contact point normally rests. Remember it has no syncros, and straight cut gears. If when you have it in gear stopped, and (holding the clutch down) put it in neutral, it should not start to spin again making grinding. If it does, and the freeplay is right, the pilot bearing might be getting sticky, (lube it) or the disk might be warped a bit, or the splines might be holding the disk against the flywheel some. Good luck, let us know the outcome. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
