Posted by D Slater on January 05, 2009 at 08:13:18 from (72.65.148.97):
In Reply to: 450 gas to deisel posted by eat more DEERE on January 04, 2009 at 19:53:09:
While the chassis are mostly the same to install a IH D281 engine I will list some things that come to mind that need changed or added. Both hood sides, fuel tank and all lines, starter, correct generator and mounts if wanted, hydraulic pump and suction discharge lines, air cleaner and pipes, part of throttle linkage, switchover lever and linkage, starting fuel tank, fan and shroud, hand crank parts in bolster if wanted. frame rails, flywheel, some wireing, power steering mount if equiped, oil pressure gage. Probably forgot something. This above is if you have a complete engine with all outside parts. I know you didn't ask for a opinion so overlook this next if none wanted. Your money ahead to buy a good running 450 D if found unless you already have the parts.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
