Re: Keystone rings
Posted by James22 on January 07, 2009 at 11:19:06 from (207.179.239.248):
In Reply to: Keystone rings posted by teddy52food on January 06, 2009 at 17:23:59:
Keystone top or compression rings provide a larger wear surface thereby will last significantly longer. However this does cause more friction and a slight loss in power with higher fuel consumption. With the larger wear surface they aren't as effective in scraping off any oil that gets past the lower rings. Also as was stated earlier, the ring grooves are "self-cleaning". I believe the more expensive Keystone ring design is a superior design due to it's increased durability and self-cleaning attribute.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
