Posted by El Toro on January 08, 2009 at 03:50:10 from (64.12.116.73):
In Reply to: Re: C Not Starting posted by Rusty White C on January 07, 2009 at 19:20:18:
If there's very little suction on your hand when over the throat of the carburetor means you have very little intake manifold vacuum. Do a compression check and see how your compression readings compare. Make sure you're getting battery voltage to the coil. With the points open your should have battery voltage on both small terminals. Clean those points with some 320 wet or dry until they're shiny. Remove the sparkplugs and squirt engine oil into the cylinders then bump the engine over a few times. Make sure your plug wires are on the cap in the correct firing order should be like this. Hal PS: Since the rotor turns CW. 2-1 4-3
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
