Re: 986 oil in radiator - 436 Ci
Posted by Owen Aaland on January 08, 2009 at 20:09:39 from (65.161.86.89):
In Reply to: 986 oil in radiator - 436 Ci posted by Mark in Upstate on January 08, 2009 at 08:14:01:
If there is any significant amount of oil the coolant it is usually the oil cooler that is leaking. When the engine is running the oil will go into the coolant. When you shut it off, the pressure remaining in the cooling system will now force coolant into the oil system. I have seen them leak so much that the oil and coolant both looked the same.
Leaking sleeves do not usually put any significant amount of oil in the coolant. Nozzle sleeves will leak coolant into the cylinder but no significant oil back into the cooling system. Unless the fuel system has been turned up head gasket failures are not too common.
I would remove the oil cooler and test it. I have a couple of plates that bolt on the cooler, one with an air nipple. I flush out the oil side, install the plates and apply air pressure. Stand the cooler on end and fill the water jacket with water. Watch for bubbles.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
