The lighting wire should (or can) be connected directly to the load side of the Amp meter. Make sure the amp meter is connected so loads read discharge (needle to left). The Big screw terminal on the Alternator goes to the same terminal (load side of amp meter). The #2 spade terminal on alt. goes to the big screw terminal on alt. also. The #1 terminal should go to a wire attached to a diode with a 3 amp capacity and 400piv rating with the diode placed so the banded end is toward the alt terminal. the other end to the ignition wire going to the coil or to the ballast resistor (not after the resistor) A 10 to 15 ohm resistor can also be used in this location (10 watt) A side marker lamp can also be used as an idiot light in this location (it must not be grounded, one lead of the light must go to the alt #1 terminal, the other to the ignition switch, or ignition coil before a ballast resistor. This setup causes the alternator to start charging I would put a 70 amp Fuse link in the wire going to the Amp Meter from the start switch. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
