Gene Bender said: (quoted from post at 04:04:03 01/13/09) Putting some ice on the shaft wont hurt a bit as metal expands something like 6 to the 7th power per inch per degree.
Not quite an exponential power, but the linear expansion would be roughly .000006inch per inch size for every degree F. Area around .000012/square inch/degreeF. Alway wise to double check my math though! :lol:
Small numbers no doubt, but [note math disclaimer!] a 1.5" shaft will be .001 larger with 100degrees F increase in temp; enough to go from a press fit to a slip fit! Cooling the shaft and doing 200 on the pulley, probably gets you to 150 difference, better yet!
A parallel question I have: anyone use anti-seize on press fits? It seems like an oxymoron, but I've found grease [pretty crusty after 70-80 years!] often enough under press fits, and wondered it anti-seize would be good for both assembly and [if I ever need to :shock: ] disassembly without affecting the fit (I don't see why it should hurt a good fit, but never tried it).
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
