Re: Farmall H Battery Installed backwards
Posted by Janicholson on January 14, 2009 at 10:51:08 from (199.17.6.128):
In Reply to: Farmall H Battery Installed backwards posted by Antgre on January 14, 2009 at 04:46:10:
Body of Message:
New info:::
With the tractor not running, turn on the lights (if they work) if the needle on the amp gauge goes to the right, the amp gauge was not changed when the battery was installed Neg ground. (if the lights do not work, a close look at the needle when switching on the ignition will also show this right needle movement, but far less distance on movement.
If it moves left with lights or ign, the amp gauge was reversed when the battery was put in Neg ground.
So, if it moves right with the battery Neg grond, it will be moving left with the battery in correctly, this is good. If you want it back to normal (stock), turn around the battery, Polarize the gen (as K-Mo below indicates) and you should be good to go.
If the needle moves left when lights are on, the amp gauge wires must be moved from post to post inside the electrical box to make it read correctly with a Pos ground (stock) battery hookup. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
